I hope you guys are taking CPU's into consideration here! Seriously guys he's only on a dual core not a quad!![]()
I'm using 177.35 from nvidia website
Strife could you take a pic of it inside your case as I only have a GT and wanna see how big it really is![]()
But still 10756 is still a bit too low for a 8800GTX with 3.2Ghz C2D? Unless of course it was running on vista.
Was that in reply to my post?
if it was ..![]()
The case you have is the coolermaster stacker right? The side window, is that something you moded yourself?
Has anybody asked yet, how does it sound when under load?
Isn't the 8800GTS G92 clocked higher than the 8800GTX?
It is a coolermaster stacker, its an official window bought from the coolermaster website.
Not noticed a difference in sound from 8800GTX personally.
Requires
1x 8 Pin PCIE
1x 6 Pin PCIE
My PSU has 2x 6 pin PCIE and 0x 8 pin PCIE (Corsair HX520)
2x 6Pin turns into 1x 8 Pin
2x Molex turns into 1x 6 Pin
Size (Sorry about shocking wiring, will re do it soon):
Only one screw to hold card in ?? with the weight of this card it would be more secure with two...
Requires
1x 8 Pin PCIE
1x 6 Pin PCIE
As far as I'm away, it's like mt PSU, it came with 4x6+2pin cables so I assume that I can run two fo these cards in SLi if I wanted, 1x6pin and 1x8pin for each card... just by bolting the extra 2pin into the hole... I'm 99% sure you can do this?Thanks for the pic. My HX520 came with 2 6+2 pin PCI-E connectors (will these not do?) and I emailed corsair asking for some more and they sent me a 6+2 and a 6pin PCI-E connector on one cable(for free, along with some more SATA cables).
