- 7 Aug 2004
Only ever update to of fubard my iphone, oh well, have hit restore now and will have to resync
engadget.com said:As some of you already know, updating your iPhone to firmware 2.0.1 means that you've lost access to all your jailbroken apps. That's pretty much expected and should be rectified by the DevTeam soon enough. What's notable from an unlocking perspective, however, is that Apple's 2.0.1 release also updates the iPhone 3G baseband. This puts iPhone 3G owners in a bit of a quandary: update now via iTunes in desperate hopes of the stability and improved keyboard response we've been seeing but do so at the risk of not being able to unlock your iPhone 3G in the future (if and when the DevTeam gets around to releasing it for firmware 2.0). A lot can happen in the course of a 2 year (or longer) carrier commitment. According to the DevTeam, you'll get all the benefits of Apple's 2.0.1 update (without the pesky new baseband) just as soon as they can kick out the updated PwnageTool (current version is 2.0.1) onto the Internets. Decisions, decisions.
Hi guys,
do i lose my settings when i do this?
New user.
If i update from 1.1.4 to 2.0.1 will i need to do ANY kind of activating/unlocking to use an O2 simplicity in the iPhone ?
Also, is the iTunes remote player thing free or do you have to purchase apps from apple apps store on the iPhone ?
The itunes my iphone 3g is synced on is an unreliable laptop.
Can I plug into my main pc which has itunes on (which is synced to my step daughters ipod) get the update and run?
For those who have hidden icons in the BossPrefs app, you should unhide them before upgrading otherwise you won't be able to see them after the upgrade and restoring a backup.
Hmmmm, my phone wouldn't come out of standby mode before. It had ample battery...
mine does that, hopefully this will fix it.
Do you have a reason for not using Winpwn/Pwnage ? That works fine with 2.0I just wish Zibri would jailbreak/unlock v2.0 for a start. Still on 1.1.4 and waiting on an Orange PAYG.![]()
After what I read about that dude im going stay way clear of ZiPhone.
Waiting for the dev team to release Pwnage 2.0.2 and then its upgrade time![]()
What have you read?
