Got my replacement this morning.
Some pics of how glossy it can be if you have a window behind you during the day.
Is this the black or silver version? Is the rear side aluminium color for both models?
I thought black model was much closer to pastel black color, the monitor in the picture expecially on the left side looks dark grey (maybe it's only the flash or the aluminium surface). What about the rear?that's quite clearly black.
Reading the manuals posted earlier, the 24" Wi screen has changed quite a bit.
The previous revision (W) had a luminance figure of 500 Cdm2 whereas the Wi (new) has a figure of 400 Cdm2
And from a couple of guys on here, this new screen has one or two issues.
Also the old 24" (W) revision had a contrast ration of 800:1, the same as the 26" model, but now it is down to 700:1
The 26" Wi model spec is identical to the W so I would expect it to have a non glossy screen and hopefully the same low input lag 16ms I believe ??
This is what I am leaning towards.
Roll on Monday !
I would think Tuesday too yesI selected a Monday 18th delivery date. Realistically this will be Tuesday right?
Damn, I had almost decided on getting the OCUK value 24" monitor but the high quality of the Wi 24" is definitely tempting. As someone who uses computers for browsing, videos and games (so no art, design, etc), is the Wi worth the price difference?
Wide Gamut on SRGB material is perfectly fine if you have a colour calibration device - you won't notice any difference but will benefit from the wider gamut in applications that support it (Photoshop, Firefox, Vista native etc).
To clear things up regarding the HZ26Wi I recieved 100% confirmation from Hazro. HZ26Wi wil NOT be GLOSSY.
That's good to know. I was easy either way about it being glossy. Hearing people complain about the reflection was causing some doubt in my mind. However if it is glossy, I won't be upset, as I don't have a light source which lands on the monitor when I am in front of it.
Why would they make the 24Wi glossy and not the 26Wi?
