If the drive bay came from an Antec 1200, the slide filters are pre-installed, one of the best upgrades Antec made from the 900.
I did prety much the same thing but with an Antec 900 HDD cage, could do with a black fan in there though.
Ye, used to have a 900, decided to take this out when i gave it away.Really like that mod, fits in perfectly.
Did you just have the HDD cage lying about? Might have to see if I can source one...
it a akasa 220mm fan, its nice and quite,pushs fair amount of air into the case,noticed quite a drop in temps both cpu and gpu,got to tidy it up a bit,its bit of mess in there.
zia
non that i am aware of,ofcourse it should be possible to make your own
zia
Decided to order a Mirage V4 over the Omega.
The omega is great case but I prefer the look of the Mirage. Should be back in stock on the 28th so will be doing a building log on 2 mirages.
my first case mod
zia
. You should really get a filter on that ASAP. My side 120mm fan was blowing in a lot of dust until i added a filter. I wouldn't like to see how much dust yours attracts...
And those 220mm fans shift a boat load of air - and dust![]()
No accept the appearance would be compromised quite a bit dont you think?
