Man of Honour
- 5 Jun 2003
- Falling...
Check with your doc. I had one when I was 16... took a month to heal, but then forgot about it and was fine, but still worth checking.
22/08/08
Workout B - Heavy
RDLs
5x44KG, 5x44KG, 5x44KG, 5x44KG, 5x44KG
Dips
5x40KG, 5x40KG, 10x20KG, 8x20KG, 10xBodyweight - PB
Wide Grip Pull Ups
5x10KG, 5x15KG, 5x15KG, 5x10KG, 5xBodyweight - PB
Military Press
5x29KG, 5x34KG, 5x34KG, 5x40KG, 5x29KG - PB
RDLs were kept light because my hamstrings were still sore from Monday, and my lower back wasn't feeling perfect.
I'm not sure about low rep dips, I think there maybe needs to be at least 6, pretty impressed with everything though.
Impressed at those dips and pull ups
I struggle with much more than 15kg for chins - but for dips I'm quite comfy on 25kg x5. Shoulder press/military press, is that DBs with or without a backrest, or at a machine? Facing forwards or backwards? eitherway that's pretty decent weight![]()
got 75kg out for 3x5 st sh press. Bet if you tried youd get more out! Those chins are impressive m8, im down at 101kg now so not much between us. Im gonna cheat my way down the last bit of bf tho, got me some clen and T3
Clen is so over rated, horrible stuff, yuk!omg i beat FF on a liftgot 75kg out for 3x5 st sh press. Bet if you tried youd get more out! Those chins are impressive m8, im down at 101kg now so not much between us. Im gonna cheat my way down the last bit of bf tho, got me some clen and T3
Keep an eye on your adrenals and cortisol levels dude...stacked with T3 at 5days on 4days ECA for 6 weeks should see the BF strip nicely
Rhodiola Rosea and Cissus might be worth looking into for this purpose![]()
(But well built!!
