- 12 May 2005
Yes it is... 60 - 70 will be made quicker.
Really? And that is in next patch?
I got my 5th netherdrake this morning, now there's nothing that I really want to do before the patch. I spent a couple of weeks gathering herbs for inscription, and deliberately got more than I think I'll need, as I think the price of herbs is going to go right up so I may as well try to cash in.
I've heard that experience needed has been decreased from 60-70 with this patch, but I can't check it at the moment as I can't get on to the ptr. Regardless though, the new talents make it a lot easier to level - my 62 paladin is useless on live, but on the ptr it kills things quickly and comes out with full health/mana!
Hmmm i might put my mage on hold until this patch then. I will lvl my warrior as prot as it looks as though i can pvp/grind and tank instances as prot! Only just got my first part of T4 after being 70 for a few months but being in a crap guild(cant even clear kara in a night).
3200 dps at level 80 seems very low for a ret pala, i am a sunwell geared ret pala an on kil'jaden i average 2.1k dps.
will 0-60 speed be remaining the same? i know its meant to be easy now but as ill be completely new to the game ill need all the help i can get![]()
Blizzard said:Dual-Spec system
* The dual-spec system will be introduced in a content patch. The goal is to let you switch specs very easily in raid, even between fights ! However it won't be possible to switch specs in the middle of an arena match.
* With dual-spec introduced in the game, there are also discussions about an Itemrack-like mod being introduced to the default UI
