If all you look at is specs, yes but if thats all you care about then go buy a dell. Otherwise unless you're blind it's fairly obvious it's a major design refresh. Macbooks have substantially better graphics too...
im a graphic designer, so yea i do look at specs. i work on a MBP
plus the glossy screen? no matter how good the color brightness will be, its gona be a pain to use out doors when you shoot photography on location.
i dont particularly like the idea that the MBPs look like or vice verse the MBs, the Pros are meant to be on their own, not in the same catagory in looks. if thats so, Pros wont need to spend that much more to stand out from the rest, they could just buy a MB and be done with it in my opinion
