I'm sure it does if you do the whole thing, but if its just the base then the difference is minimal.
Aye true. Base plate is going to be the least affected of the panels (smaller, fixed and feet reduce vibration)
Tetsu: Just ordered those black mesh PCI plates for both my Akasa Eclipse 62 & Lian Li Armour..Makes a suprising diffrence to the look of the case you posted..
They do look nice Tetsu. Who makes those mesh plates? Does OcUK stock them? Might bung some in on my imminent PC order. Especially if dust won't get it but a bit more air circulation helps the graphics card keep a bit cooler.![]()
Found some.
How would I achieve positive pressure? More fans blowing in than out? Or vice-versa?
Will those PCI plates fit any case?
so i was browsing the web looking for some ideas for when my Omega comes on tuesday and came across this, IMO this is probly one of the best ones i've seen. love the Orange on Black.
Long overdue picture update on mine (not very good photo)
with the WC setup.
weekend photo shoot time for the case![]()
with the WC setup.
