- 5 Jun 2003
- Falling...
Agreed. A good frame actually - just need to try and draw in a bit of that BF and you'd look fantastic.
You're very lean aren't you!
Good back development though your traps need a bit filling out near the top. Nice triceps. Shoulders and chest need a bit of development but that might just be the angle/light of the camera.
Nice taper going on too. What are you after? Size or just definition and cut to shreds? What are your "stats"?
I take it these are your "before" pictures?I need to start juicing then...
cheers
My shoulders and bi's deff need development!! My chest is fine, I think it was how far I was pull my arm/chest back for the side sorta shot. I think I agree with you on traps too although when I'm unflexed my traps curve down to my shoulders nicely..
In terms of what I want right now.. Strength is a priority, reasonable amount of size and some rippage (but not to shreds) would be nice
in terms of stats 6'1 and a bit and about 84kg with little legs
(I train my legs but they are still tiny weeny)
edit: I need take some measurements.. All I can think is my waist is about 33'in
Catching me up!AS you say a little bit up on water retention which doesn't do your definition any favours - however it's clear to see that the bulk is there.
Good stats for your height - at your height with my goals I'd be aiming for at least 16st, but then again I'm aiming for 16st now and I'm a bit shorter than you. I suspected it was the camera quality, also it's a bit hard to tell just front on and with a camera phone it's not easy. What weight were you at your peak? You seem like, me, prefer to be bulky and strong rather than super cut and shredded (much better IMO
). Nice slim waist too - I'm not quite that slim, but I have a very thick trunk and always have done.
What are your lifts like? I suspect you're pretty powerful/strong..
I'm looking at 220 around 13% or so, but obviously more if I can but I'm not as tall as you so 240 I think would be beyond my genetic limit, certainly for being as low fat as I currently am which I don't want to lose - I like my powerful trunk. Luckily I am able to lean bulk though it takes longer and is harder work than just going for a full on bulk. All that I'm taking and will ever take is whey and fish oils I don't doubt you'll over take me on the ripped and bulky look within a year. But you do have some way to go![]()
I'll race you to 600kg on lifts if you want?![]()
Not particularly....yet.
Best lifts so far.
Incline Bench, 90kg x 11.
Shoulder Press, on the Hammer Strength 80kg x 9
Close Grip BP 60kg
Barbell Curl 40kg x 12
Leg Press 320kg x 14
Squat 120kg x 9 (Done as the last exercise of my leg work out.)
Haven't got any lifts for DL's bent over rows etc as It was my back that I injured so I use machines for back workouts and don't DL.
