I know I'm a bit late to the party, but I can't believe they are still using the same hinge as the P180 on the front door. I've broken two![]()
Just don't move your pc around with the door open. Make sure its always closed.
heheh, i just padded my case with some Acoustipack material! quite good i say! that along with how padded the case is originally i'm quite happy. just bought some fans. a mixture of noctuas for high pressure cooling and some nexus for case fans.
anyone know if there are any aftermarket coolers proposed for the 4870x2? its a pain in the bum to cool and keep quiet. even the 8.10 drivers dont do much to control fan well!
so an idea. how does a small water loop around the GPU only sound? with a little mod even the RAD needn't be that large.
Looking at that it has a bad vortex problem below the graphics card..Found this and it is quite interesting...im guessing it is showing how air will flow through the case.
