- 28 Feb 2007
- York
Just orders some,
I may have a dabble with Windows 7 again,
Ran Prime 95 for 40 mins no errors cpu temp 58 think this is classed as stable ?
Your only unnng the Ram at stock so it should be stable 24/7
Does your CPU not go higher ? You should see better performance if you clock it at 400 * 8
Get your ram overclocked too
I will try for higher tonight Im hoping for at least 3.4 ghz if the temps only high 50's under full load at 3.2 ghz.
Is lowering the mutiplier and going for a higher cpu fsb going to provide better performance then ?
Whats the max overclock seen with the kingston memory so far ?
Ta
Hey CoolHands,Would this be any good on my system?
Whens the next price drop on these then?
I should have bought it this week!! Awwwwww......Gutted i didn't act straight away!
They're all of £2.55 more !
Creidt crunch has got you hasn't it![]()
Just got mine delivered to work
Thers no sticker on the RAM stating its required voltage and timings!
HELP!!!!!!!
Any cheaper and they will might as well give them to us.
lol
