Yep, just done it and working fine. Just called up the drivers from the USB drive (though not sure if I had to, I just selected the option). It all went very smoothly and is working well on RAID 0 (touch wood as my last array on Vista failed).
Now we have separate preview windows I don't mind it being combined.
Ah excellent! Wouldn't be able to point me in the direction of these drivers would you? Ta!
I just got the driver from my motherboard manufacturer's website (Gigabyte). I'm not sure whether the intel chipset drivers are motherboard-specific but I'd play it safe and get the driver from the website of whoever made your mobo.
Can you upgrade from Vista to Windows 7?( trying to avoid a fresh install if poss).
Well you can with the beta so I imagine you'll be able to with the final release as well. I don't normally take the upgrade path but thought I'd give it a try for once and it all went very smoothly.
has it cocked up anyone elses msn messenger?
even uninstalling sp2 i cant repair the live install.
