My technical F1 knowledge wouldn't fill a postcard. Can someone explain in layman's terms what a diffuser is/does and what makes it illegal or otherwise?
So what's everyones viewing plan for Australia then? (TV details here). I was going to watch first practice (as the first bit of F1 being shown on the BBC) on the red button but realised I had to go to work the next day, so I'll probably just watch the Quali and race live and skip all the practices.
Have a look at the Toyota and McLaren diffusers. That should give you an idea what a diffuser is and what the difference in the two rule interpretations are.
Basically, the rule was that you couldn't have a diffuser higher than (IIRC) 120mm, but Brawn, Toyota and Williams have dodged this rule by using a different piece of bodywork to effectively create a bigger diffuser. Personally, I think what they've done should probably be illegal since it deliberately subverts the rule; however, I don't think they should be penalised for racing with it (since the FIA didn't draft the rules sufficiently clearly) but instead just told to bring a new design after Malaysia.
(edit) Got the details of the rule wrong - see here.
Basically the boffins at Brawn, Toyota and Williams have done a better job with the diffuser rules (not technically illegal) so good on them
You can bet the other teams are currently working on a diffuser just like the one they say is illegal just in case
Indeed, it's just another in a long line of these...yup this is the thing, f1 design is about interpreting the rules and making the best design out of it. The other teams didn't come up with this idea, so want it banned/rules changed. Its how F1 works![]()
Other teams being Ferrari! If Ferrari had the questionable diffuser then you bet it wouldn't have been banned.
I'd forgotten why I wasn't going to post in this thread again. You just reminded me.
The scary thing is I'm struggling to think of anything more modern that's been designed by one team and then picked up by all the others rather than being banned - the wheel disk things I suppose could fall into this but they're not as radical or controversial as some of the above.
I was wondering how long it would take for a comment to bring you back![]()
Don't go againActually, I 'came back' to answer a question about what diffusers are.
