Don
- 20 Oct 2002
- In a house
I thought that the device charges and then stops charging when the limit is reached. (hence the arguments about variable braking forces)
So the full 6.6 seconds of use would have to be fully charged before it could be used again. So, double use on the straight would not be possible.
However, if you nail the full 6.6 seconds of KERS on the start finish before you start the lap, your speed on the straight will be increased when you start the lap, and by the time you get around to the finish line, you will have used another 6.6 seconds up
