anyone tried an electric bike?
Is it just used for uphill? flick a switch?
http://www.cyclelane.co.uk/products.php?plid=m6b0s129p719
Fantastic bike, if you are a 90 year old
I've put 20 miles on the pitch today. Gonna at least double that tomorrow.
First impressions are i'm impressed with how little the suspension bobs. i.e. it doesn't bob at all unless your out of the saddle mashing the pedals. Also it's better up hills than i thought it would be considering it must weigh 32lbs.
Despite the lack of pedal bob the rear suspension feels fully active. It seems to perform better than the pikes which seem a little stiff and i'm not light at 13.5 stone. The pikes don't have ANY preload adjustment so i'm stuck with only 15% sag right now. I have a feeling they would be much better with more sag.
I've built a 3ft ramp in my back garden. This pretty much is the most I dare do on my rockhopper. On the pitch I might aswell not be going over the ramp, it's like landing on a cloud - i love it.
Can't wait to test this thing properly on some more demanding terrain.
i wondering guys if you had upto 1k to spend on a full suspension bike what would you get?
the special fsr XC looks good, or the GT I DRIVE. also.
what would you go for?/best around.
http://www.southerndownhill.com/forum/index.php/topic,193642.0.htmlHola ladies and gents need some advice on Bicycle insurance who do you use and recommend??
Having just priced my bike for the house insurance renewal they will not insure any bike over £1500 so I am going to be looking for an independent insurer.
Thanks
Marzocchi aren't producing the best forks at the moment, you should look at Rock shock and within your budget as said above you should get
RockShox Tora 318 Coil U-Turn Fork £240 or if you want air and not coil RockShox Tora SL Solo Air Fork
