I didn't realise there was that many differences.
I thought it was the same GFX Card between the late 08 and 09 versions?
Wikipedia suggests that the only difference is the CPU and the DVI Port?
I was talking pre-unibody, sorry to confuse you.
Thanks for the advice, both of you.
I'm guessing the 2.53Ghz use to be the highest spec 15" then?
Slightly off topic, but has anyone here ever bought AppleCare off eBay before? Is a whole lot cheaper.
For your original question, I honestly couldn't see a problem in buying applecare off ebay, just ensure that the applecare is specific to your make and model of mac![]()
Is it worth holding off buying a Macbook Pro right now? Seen rumours that there will be improvements to the range announced at WWDC?
Me too, especially given the minor updates earlier in the year too. But I can wait a couple of weeks to find outI think you're spot on.
Thinking of getting my first mac for my birthday in june. It will be the entry level aluminuim one (uni-body?) and i just need a few questions answering.
Will i need any addition software in terms of anti virus or will the macbook be fine without any of that extra bloat?
Does the touch pad work well or is it worth getting a mighty mouse too?
Would Apple be the best place to buy the macbook or shall i look elsewhere considering the decreased price. Is it the same package or are you left without warranty or anything?
Also how easy would it be to transfer my itunes music/applications to the macbook from my pc or if i can from my ipod touch?
Sorry if some of these questions sound a bit strange or stupid but just need a few things cleared up.![]()
Would love a laptop which boots within seconds
Realistically I never, ever shut down my MBP, just close the lid and let it go to sleep. It wakes from sleep in a couple of seconds to being fully usable and that's without an SSD.
