Haha. Your use of 'rely' and 'serious work' were clear FUD in the direction of Windows and you act surprised when someone takes you up on it.Now you got a response from me so kindly go back to your PC and stop trolling the Apple forums.
EVH said:I have found Windows 7 to be stable enough to use on a day-to-day basis, and in fact I can't remember a time when XP or Vista crashed, but I'd still use OS X.
As I think you'd agree.. it's down to personal preference and trust.
Like I said, if you can prove that the machine is at fault then get it sent back for a refund.
I don't understand why you're putting up with it..![]()
Because what else am I supposed to do?
Edit: Im one of the prefer OS X brigade...
Push and push hard for a FOC upgrade. The situation you are in is simply not acceptable and definitely not from a company that prides itself on customer service.
Oh and be careful sticking your head above the parapet in declaring yourself a preferrer of OS X as you may get the PC brigade saying you'd have been better of with a Dell!![]()
So why bring it up in your reply to Bes?Not so. You can as many people do use Windows for 'serious work' - just because I wouldn't rely on Windows for my serious work does not mean others may chose to do so.
Gimme a break. Textbook FUD to casually throw those terms in without explanation.Nothing to do with Fear Uncertainty and Doubt but simply my opinion based on my technical understanding of Operating Systems and my experience working with them.
Yeah, getting involved with tribal BS, how annoying.However as often happens on a forum dominated by Windows users you get cries of "fanboi" at the whiff of somebody preferring OS X.
Try a wired keyboard/mouse, I've had my MX rev pause at times under OSX...mouse and keyboard inputs pause, whatever your doing.
Do you use a Mac workstation for this serious work at home? Because if not, and given that people can and do use Windows for serious work (as you say), I can't see why you take issue with Bes's suggestion of a £1000 build being a perfectly solid machine.Because he rolled out tired diatribe out about how a £1000 pound PC can do the same as a dedicated Workstation. You will also notice that I compared his generic £1000 PC to Workstations from Dell, HP and Apple all running Workstation class operating systems.
I also expressed and opinion that I'd do (as I do) all my serious work on a Mac rather than rely on Windows. I even paid a passing complement to Vista in its current form (far better than it was!) but I guess you missed that!
Obviously. The only reason I questioned you is because you later got ****y and called philjohn a troll (my, he used the word ridiculous!!) when he took you up on your insinuation that Windows wasn't suitable for work that is to be relied on, which was perfectly reasonable, seeing as you gave zero explanation.some people prefer one way of doing things and others prefer other ways.
Weird, I'd send it back!Wired, bluetooth, using screen sharing by the MBP.
All the same.
Surely having a fully functional Mac Pro is worth the hassle of messing around with a few external caddies.
or none at all!I can't see why you take issue with Bes's suggestion of a £1000 build being a perfectly solid machine.
Should have bought a Dell tbh![]()
I here the Dell Mini 9 is a very good laptop especially for turning into a Hackintosh laptop!![]()
