- 17 Sep 2006
- Gloucestershire
Not long finished machine polishing my mates 172 cup. We started at 9am, and finished just after 6pm....Im knackered!
SoliD asked me to have a look at the Range down the road to see if they sell Nilfisk pressure washers as detailing world recommended them above Karcher ones and lo and behold they sold em - £39.99.
I scanned the barcode on my phone and the cheapest it found online was £54.99 at a competitor so I bought it
Used it to clean the wheels and test out the power on some paving slabs out back and it's pretty powerful, managed to rip away the dirt ground into the slabs and of course the break dust from my alloys
Will do a proper clean over the weekend or on Monday.
So far it's excellent, can get some snow foam now too as it comes with a cannister that attaches on.
http://robbiekhan.co.uk/root/photos/cars-mine/nilfisk_alloycleaned.jpg[/mg]
[img]http://robbiekhan.co.uk/root/photos/cars-mine/nilfisk_front.jpg[img]
[img]http://robbiekhan.co.uk/root/photos/cars-mine/nilfisk_rear.jpg[img]
It comes with the shampoo/foam cannister, 2x heads (rotating blast and flat blast).[/QUOTE]
Where did you get that one from chap? :)
My mum got me one of these, they are crap.
Get the halfords sheepskin washmitts, I have just got a few and the quality is better than the Eurow's from CYC which have started to fall apart after only a few months.
Where did you get that one from chap?![]()
the sheep skin one i had for a few years went hard and bits came off it. the asda one is much softer and you can do grimey bits with the reverse side
autoexpress thought it was the nuts tool
<snip>
That really confused me, i though you had just taken a moving picture of your street at first
Nice finish!
Hi Guys,
Havent posted in these forums in ages, and i dont think i ever have in the motors section, but I was hoping that someone could recommend a place where i could get my car detailed/waxed nicely, somewhere near East London.
I just bought a 535d in black and it has some really really bad swirls in it, and tbh i dont have the time, or the patience to do it myself. Thanks in advance.
that's why you get a sealant or wax that sheets instead of beads![]()
