nope. it's the internet bandwidth usage. also my network usb hub is disconnected so it not that.Cant' be right. Home network usage?
config file says downstream 53000000 bps which = 53Mb and upstream 1750000 bps which = 1.75Mb. so i'm getting alittle more than 1.5Mbpretty much impossible to be getting more than the 1.5mbps, these cable modems run off a config file and i doubt yours gives 3mbps![]()
yeah. tbh when i was on 20Mb package speedtest worked fine but on the 50Mb package it doesn't..Speed test always given the results it should no matter what internet connection i use, but i tend to use real download facts rather than speed tests currently downloading at 5.95mb/s more than happy with that, first few days it was abit flaky but now its rock solid.
config file says downstream 53000000 bps which = 53Mb and upstream 1750000 bps which = 1.75Mb. so i'm getting alittle more than 1.5Mb![]()
well when i download i am getting the full 53Mb, but the upload speed im getting 1.62Mb now. so i guess maybe im luckynot after overheads you aren't![]()
sorry fo the post but wanted to ask....
Has anyone upgraded from 10Mb to 50Mb? I was looking at it but called them up and they said it would be an extra £45??? Anyone had any bargains on getting an upgrade to 50mb for cheaper?
Say you want to cancel your account, I bet you get a good deal that way.
