- 19 Oct 2002
- Torbay, Devon, UK
8GB RAM issues causing low fps
A friend and I have near identical machines apart from I have double the RAM at 8GB. Both ordered and installed new ATI HD 4890 cards and set Arma graphic options to the same. To cut a long story short he got 60fps constantly, I was getting 10-20 fps! If opened in 1680x1050 then all I got was black blocks everywhere.
This appears to be an issue mainly with ATI cards with 8GB. To get this working I had to add the -winxp line fix to the target shortcut although I understand this does not work with all machines. Seems crazy cutting your RAM in half so another option is to limit the amount of your RAM via msconfig to a higer number.
Not sure if this has been covered already - apologies if so. Since then it's been amazing![]()
But do you now get the same FPS as your m8.
Has anyone done a test to see if taking 4 gig out and getting rid of the -winxp makes it any better.
