More likely u use open case at all times ? No side case to put it back on ? It will heat up more once you closed the case and that's what happen to my H50 soared up to 88C when I closed the case. If open the case, it drop to 81C.
I don't like intake hot air blow inside the case from H50.
The case was closed for the test. It was opened to prove I had one and the fans take air from inside the case and exhaust it out the back like any other cooler.
My HAF932 has a 230mm fan on the door anyway.
Mate I remember when you were telling everyone that the H50 was the best cooler ever and your temps were below 70c so just be quiet or prove your findings.
(joke)
