- 23 Dec 2006
- Wakefield, West Yorkshire, UK, Earth!
Awesome, that is impressive
I would've said it's impressive regardless of whether he's a natural or not.
Each to there own, defiantly not my opinion!
My current program hasn't stalled, though I feel like a bit of a change (should I stick with my current program?). I might try just doing lower rep ranges then for compounds and higher for other exercises. I did try pyramiding yesterday and it kinda failed due to endurance;Has your current program stalled? Some people will say keep to a lower rep range on the compounds and just mix up the other exercises (so would I). Or you might want to try totally mixing it up with pyramids etc.
Find fault with this thenStraps, bouncing, hitching.... what a wuss![]()
If your current program is working well why change?
Don't worry about being knackered when switching to higher reps, you will get used to it.
Is this the time spent on pushing/pressing then the negative? I tend to do quite slow negatives but I've never really measured it. I'm looking to increase in size/lean bulk and a fair increase in strength. (I might keep going in the 6-8 rep range till I can bench 90kg for 6 reps)Might be worth looking at your rep tempo depending on what you're trying to achieve.
To be fair to Poundstone he's a strongman so doesn't have to lift as strictly as KK who's a powerlfiter. It's basically just a case of getting the weight off the floor and locking out at the top. What happens in between each rep is irrelevant which is why he's all over the place.280lbs and his abs are rockin, beast. That ones even better than the last imo.
That might explain it. Both very impressive though.To be fair to Poundstone he's a strongman so doesn't have to lift as strictly as KK who's a powerlfiter. It's basically just a case of getting the weight off the floor and locking out at the top. What happens in between each rep is irrelevant which is why he's all over the place.
While we're linking crazy stuff-
