Caporegime
- 9 Mar 2006
- Surrey
Ah yes, the same as the console version limited edition then. You unlock it after finishing the game anyway so I wouldn't worry too much, it's hardly special.
Hey try it on friday then see what happens!
officially the game is not out yet!!!!!!!!!!!!
Armoured suit or something like that
AWPC, that the extra scarecrow challenges ?
I heard there was joker ones as well on PS3 ?
Is there a list of the DLC contents?
i cant download the patch!Also my setup has no physx option! Also i've installed the game but it never asked me for a activation key code lol
Only need the key code when you log into Live, and when you do login, it should come up with an update, when installed, should bring all that PhysX stuff (i have it on Steam, its all there).
the only problem is,That i log on but no screen with the key,I will have to try later.
Hit your Home keyboard key or the guide button on the 360 controller this will bring up the GFWL interface and when you try to connect to live it will prompt for your live access key and after that you will gain access to the DLC & patch as both are controlled by this to ensure legal copies only get the content.the only problem is,That i log on but no screen with the key,I will have to try later.
