- 20 Apr 2008
- West Midlands
nice. post back with some benchies/impressions![]()
yeah do your Frank Bruno. cracks me up
sorry Guru, couldn't resist
just found Beta ati 9.10 drivers.
http://support.amd.com/us/kbarticles/Pages/ATIRadeonHD5800seriesrecommendedgraphicsdriver.aspx
sorry if ppl have posted it first.
Oh they are quite a bit newer than the ones I posted the other day, dated Sep 21st, ones I posted yesterday were the 14th IIRC
Mine turned up about 30 mins ago
Got to say it is huge, biggest card I have every owned. Weighs a ton also.
I think we will see the odd person disappointed today when they find the card doesnt fit their case.
Once I get it setup I'll do a comparison to the 4870 512MB on crysis 1920x1080 veryhigh no AA, wont be until lunchtime though.
Mine turned up about 30 mins ago .
can you show us the difference in size between these aswell and also how tight it is inside your system
daz
run NFS shift. 8xaa16xaf 1920x1200.
and tell me the minimum frames you get.
man i hate waiting my 2 5870s will be here shortly for some crossfire action lol
Just got mine, its had offical backing by charlie the dog:
Ah, interesting - I never knew that. Ta
Rancid Elf - Dr Raith suggests you are looking a bit pale and should go home early; I think you might have a non-specific one day virus.![]()
