- 20 Apr 2008
- West Midlands
nice. post back with some benchies/impressions![]()
yeah do your Frank Bruno. cracks me up
sorry Guru, couldn't resist
just found Beta ati 9.10 drivers.
http://support.amd.com/us/kbarticles/Pages/ATIRadeonHD5800seriesrecommendedgraphicsdriver.aspx
sorry if ppl have posted it first.
Oh they are quite a bit newer than the ones I posted the other day, dated Sep 21st, ones I posted yesterday were the 14th IIRC
its what im using so far.Mine turned up about 30 mins ago
Got to say it is huge, biggest card I have every owned. Weighs a ton also.
I think we will see the odd person disappointed today when they find the card doesnt fit their case.
Once I get it setup I'll do a comparison to the 4870 512MB on crysis 1920x1080 veryhigh no AA, wont be until lunchtime though.
Mine turned up about 30 mins ago .
can you show us the difference in size between these aswell and also how tight it is inside your system
) in my casedaz
run NFS shift. 8xaa16xaf 1920x1200.
and tell me the minimum frames you get.
man i hate waiting my 2 5870s will be here shortly for some crossfire action lol
Just got mine, its had offical backing by charlie the dog:
Ah, interesting - I never knew that. Ta
Rancid Elf - Dr Raith suggests you are looking a bit pale and should go home early; I think you might have a non-specific one day virus.![]()
