- 30 May 2009
- Maidenhead
I will defo be looking that XMS3 then. Sounds like damn good RAM for the price ^^
Still undecided on weather to get the Corsair XMS3 or try the OCZ Obsidian. Does the Corsair have XMP??
Just ordered my Corsair XMS3 1600MHZ RAM. Be here tomorrow, so going to see if it can handle 1600MHz then ^^
I am very sure it will my friend. Just tested my new 6GB at 1600mhz and 4ghz. Absolutely no problems. The Corsair ram itself is very good stuff.
McT![]()
Sweetness. Hopefully it will be good for me. I'm just really hoping my IMC isn't the problem. But I don't think it is, as it wouldn't run the Patriot RAM @ 1600MHz and stock CPU settings. Can't wait for this Corsair RAM. Sounds epic.
Just a wee update here. New Corsair RAM is now here =D Off to install, and then test these babies @ 1600MHz!
Ok. I installed my new Corsair RAM. All seems fine. Set the multiplier to 8x. Once again, same problem as before =( Then...I discovered I was a giant idiot. For not setting my Uncore multiplier to 2x the RAM multi. Boots fine @ 1600MHz. Now just need to run Prime95 and LinX with full memory.
I was going to check that one lettuce. However, with the uncore at 16x and RAM multi to 8x the Patriot RAM would crash during Prime95 blend.
This Corsair is running fine so far. I will test it properly soon. Ran for around 1.5 hours fine. Need to run longer later.
