Its the same as a 75W-90 gearbox oil
I have been reliably informed that MTF94 is a very similar spec to 10/40 semi, so much so that Rover used to recommend it before moving across to the MTF.
Fair enough, I only had the 10/40 in for a few K and it came on looking like crap!
After much searching I got the 94, although it was a pain in the ***
Who were you on MG-Rover.org again? Memory fails me
Mat, you mean you were able to undo the gearbox filler plug?
Even when I had the box off, I couldn't get mine undone.
I just fill through the speed drive instead!
Need to manup to be honest Andy. Real men can undo any stubborn bolts etc.
Seems to be too common to be otherwise eh!
Could a sticky caliper account for 2-3mpg drop?
Stuck caliper, yay!
On Monday I'll be stripping it down and rebuilding, this should be fun. Wish me luck!
Recon caliper and a set of new pads would be the best option....
Dave, you didn't used to own a charcoal 420 GSiT did you?
I remember the username from a few years back.
Any reason for this? Seems they come up fine when rebuilt
