lambda said:polishing a turd
"The act of trying to make something hopelessly weak and unattractive appear strong and appealing. An impossible process that usually results in a larger, uglier turd. "
Bit like your two posts.
polishing a turd
i can also pretty much gaurantee ive had a better education than you, so get over yourself.
You might want to review and get a refund on that education then, anyone with half a brain knows the phrase you can't polish a **** is incorrect.
don't regret... nice... good condition... rear...16 year old!
Stuff of legends from what I hear![]()
10w40 in a gearbox? 0_o lol
I need to do the gearbox and diff oil in the 5 at some point, gbox filler is a bit of a sod to get to so I'm gonna but one of those pump things to make life easy. Can't overfill it either, it just dribbles out the filler hole when it's full![]()
Mat, you mean you were able to undo the gearbox filler plug?
Even when I had the box off, I couldn't get mine undone.
I just fill through the speed drive instead!
