*** Official OMG I've finally got my 5850 thread **
MSI Afterburner & AMD GPU Clock Tool
Ok, Well it did not for Me, what operating system You guys using ?
I will tell You something else, initially I was at a total loss because previously HWmonitor was giving me core volts, while running GPUtool and Afterburner I was not seeing any voltage increase in HWmonitor ! I posted the question I did not understand the change to Afterburner config file for that reason.....none of You Buggers replied anyway :p
So we do not know for sure but the Voltages in Afterburner may be request voltages ? either way they are 100% incremental
The voltage increase in afterburner definitely works because we are getting 1ghz core and the benchmarks prove it.
I totally believe the VDDC temps in gpu tool and that when it goes to 1.6v it goes to whatever the max voltage the hardware will allow.
Do You know which temp is which sensor ? I just get ..
GPU Temp #1
GPU Temp #2
GPU Temp #3
unlike the readout for the 5870 cards
goto C:\Program Files (x86)\MSI Afterburner\Profiles then edit the VEN_1002&DEV_6899&SUBSYS_0B001002&REV_00&BUS_1&DEV_0&FN_0.cfg
should be this:
[Startup]
CoreVoltage=0
CoreClk=0
MemClk=0
FanSpeed=0
[Settings]
VT1165_Defaults = 17 33
hwmonitor won't show the voltage increase
Yup, how come it works for some and not others because in my case I can't up the voltage :(
u need to goto C:\Program Files (x86)\MSI Afterburner\Profiles then edit the VEN_1002&DEV_6899&SUBSYS_0B001002&REV_00&BUS_1&DEV _0&FN_0.cfg and add this
[Settings]
remember to run notepad in administrator mode.
should be this:
[Startup]
CoreVoltage=0
CoreClk=0
MemClk=0
FanSpeed=0
[Settings]
:) Thanks Gareth......But it's too bloody late now :D
and regarding HWmonitor, I realise now :D...That's why I assumed I had miss read the instructions
Hopefully anyone else picking up this thread will work out as Myself You May have to just trust and bench ;)
My vantage score @1ghz. Obviously suffers from lack of physx.
GPU Diode (DispIO)
GPU Diode (MemIO)
GPU Diode (Shader)
all 3 are about the core/die/shader
Thanks, hopefully an updated version will give us the full readout as for Me in XP I just get the above 3 and fan and Core temps and clocks, still strikes Me a little strange You need 3 diode's on the Core though !
the core and shader are on the same die, right? thats why all 3 temps are close together.
