- 30 Aug 2007
Anyone got any reviews of these cases yet?
Only seen this one (in swedish, but I just used google translate):
http://www.sweclockers.com/artikel/6197-fractal_design_define_r2
Hmm looking at the pics in detail posted above, I think I will keep my Lian Li, the panel exterior finish does not look as nice as the brushed alu on the Lian Li even though the case costs £30 odd more than the Lian Li !
Where's the £30 from? They look about the same price. I assume you mean the PC-7F?
Thanks, looks pretty good for the money on the whole.
Thats what I thought too. Strangely difficult to find a quality, non-flashy, well ventilated case for less than £100
Did wonder about the reference to it running a bit warm though. Pondering where an extra fan would be best put...
like this casebut...i need atleast 2 5.25 drives
if it had 2 5.25 drives i would have sold my lancool k62 case and bought this! I need a card reader, fancontroller and dvd/blueray drive.
Still nobody knows if any of that hdd are is removable/detachable ? this case would have been perfect if it was a little bit bigger and the hdd chassis was removable like the eclipse.
Based on observation...
The HDD bays appear to consist of two single piece stamped sheets of steel which the HDD rails fit between.
Those two sides which make up the HDD rack are braced halfway down by another section of steel sheet probably to prevent bowing for whatever reason which could cause the drive rails to come out of their slots.
Fixed top, bottom and middle probably by pop rivets, possibly by screws.
Looks like tools will be required to remove the HDD rack and if you only want part of the rack out, one tool is likely to be a dremel.
'No' probably would have sufficed!
It's a shame they're not removable, I imagine airflow would benefit from them being open and having those front fans there.
Fans now live on website!!!!!
http://www.overclockers.co.uk/search_results.php?sortby=&groupid=701&search=fractal+design+fan
so does the case come with 2 120mm fans?
