what version of gpu-z u used?
Whatever the latest one is. 0.3.6 I think.
You don't need an Asus one, just flash it and use MSI after burner.
Flash it to - an MSI one or an ASUStek one ??
well that should have worked...Whatever the latest one is. 0.3.6 I think.
Haven't gotten my new blocks from aquatuning yet,
I see they have their own block that is cheaper than the EK one, is that what you intend to get?
It just says 'bios reading not supported on this device'.
Broke 40fps with tessellation on. Not bad for a quiet HTPC
5850@975/1300 [email protected]
Edit; now getting 42.7fps with the 5850@1050/1300. needed 1.35v though so I'll stick with something lower for 24/7 use.
As the memory won't clock beyond 1300mhz, going with a full block seemed like a waste of money so I decided to stick with a core block.
well ive just run it with the same settings as you but my cpu is at 3.2 and card isnt overclocked and got
22fps and a score of 530 ,might send this back and just stick with a 5770 for my htpc
It's probably the Athlon 620 that's bottlenecking the 5850. A 5770 would probably be a better choice to go with that.
thanks for the advice might swap my system around and put the 8500 intel system in and put the athlon with my 260gtx,should be fine that way shouldnt it
yes wolvers69,so going to put the intel in my htpc and also leave the 5850 in with it and put the athlon with the 260gtx in the desktop as looking to play my games on my 50" plasma now,the wife can use the desktop system for her facebook
