Permabanned
- 14 Jun 2009
Doubt it is eligible with XP. Only usually applies to Vista
Can anyone confirm about the free Windows 7 upgrade - Is this guaranteed? Been told this is not eligible as it is XP!
Don't know why he has posted that link. It's old news now anyway!Link says it has been flagged and suggests it may be malware. Anyone else tried this?
Defiantly worth getting a 2GB stick. Makes a huge difference to performance in all tasks.Can anyone confirm if it is worth getting extra GB or 2GB stick? I have seen people say it depends on your setup but thought I would ask those of you who have tried both.
Mine should ship Monday...
Because this saves hacking ION drivers to work on ION LE, the links you refer to are about hacking drivers, which we all know about certainly, but this fix alters BIOS DMI so that driver hacks are no longer required.![]()
Which would void your warranty and potentially break your system.
Also you don't have to used hacked drivers, you just tell it to use ION ones instead of LE ones, there is no hack or editing involved.
I think I'm gonna settle for one of these. Shame about the glossy display though :/
i plucked up the courage to do it and it worked. From what I can tell it simply lets you change bios settings that you don't otherwise have access to. If a warranty issue develops and you can still boot the machine, you can still change it back.
Using normal unhacked drivers works the same as hacked ones or the bios tool. The result is the same - the system thinks it has (which technically it has, but lets not go there!) a full DX10 ION. No need to edit any drivers and certainly no need to void your warranty.Unless you require DX10![]()
Unless your PC doesn't boot for some reason, then you're screwed.You certainly canusing the BIOS recovery flash procedure
