awsome submarinewere u get it?
My local LFS sells them. It's enormous and I keep being tempted!
I got it from Aquajardin
next question are all the plants real or plastic?
Your over feeding and its a Diatoms type algae. Its harmless and normaly the first type of algae to show up in a new tank, algae eating shrips or algae eating fish will eat it. Use plants to out compete it as for cleaning the sand just give it a stare.
Real. The main one is a Java fern growing from bog wood.
really like the look of it, is a nice tank, do you have to change the bulbs in order to have real plants of is the standard bulb you get with tanks enough?thanks for the tips, does the algae clear up on its own when i cut back on the feeding or will i need to get something to eat it?
I just got together my bits for my new aquarium on my desk at work.
Its 8 litres....
Tank - 20x20x20cm cube!
Filter - Tiny Hang on Back Variety:
Light - Arcadia Arc Pod
It will initially house a couple of plants, shrimps, and a snail. If its stable, and water conditions look like they can cope, then I might add a couple of the tiniest rasbora species I can find. Although, I am not sure how the filter will cope with the bio load in such a small volume of water...
Still, should be a fun little project, and end up looking something like this...
I like your plan, I fell foul of having a small tank and overstocking it a few years back, but I like the idea of having a mostly planty tank maybe with one or two tiny fishies in it... Let me know how it goes!
Where did you get your stuff from, anyway?
Finally the only other thing is that a lidless tank evaporates easily, leaving you with a lovely crusty tidemark around the top, and also concentrating any chemicals in the water... so be sure to be good on your water changes, a pint per day would probably be a good plan for something that size...
How long has the tank been up and running? If the sand is relatively new this will be the source of silicates the algae is feeding on.
that I'm upping the plant content, is it worth getting CO2 injection? Sounds like maintaining a decent CO2 level will improve the plant growth and quality but i'm concerned it'll be overkill for the size of tank?tank is about 5 weeks old and the light is on from 9am-9pm on a timer. fish have been in 3 weeks ish.
Just testing different scapes. I think i like that
Hi guys random question but i need some help and advise on setting up a small starter fish tank for my girlfriends little sister.
She only wants a couple of small goldfish but i want to make sure i do everything right as i don't want to kill the fish through my own naivety. My parents used to have a huge tank when i was growing up with all sorts of fish in. But I feel that they, as am I, are now out of the loop when it comes to tank preparation and fish.
Ive tried asking for advise in the local pet stores around me but most of the staff are useless.
( some awesome set ups to guys )
How would i go about preparing the water and tank? before getting the fish etc, and beginners starting advise would be much appreciated.
If you plan on keeping corals then think ahead, after you will place few corals your aquascape will change. I am now in need of rescaping as I cannot place corals easily anymore or the way I would like.
thanksreally like the look of it, is a nice tank, do you have to change the bulbs in order to have real plants of is the standard bulb you get with tanks enough?
Does anyone know how I can upgrade my lighting? I currently have 2 x 15 watt T8's in a 30 US gallon tank. My plants are not fairing too well and I really want a planted tank. How can I go about upgrading the lighting?
Bennie is giving good advice to, on the issue of stirring the sand the thinking is that your are cutting it off from the light and in turn killing it. When it brakes down you can then get it into the water column and remove it by means of water change. If you keep siphon the sand out with the algae you going to have to replace it with new sand. which will then feed back into that algae problem./snip
