I'm waiting to see what the supersonic is like!
When is more info on it due?
Not a fan of the Iphone, mainly cause its made by Apple![]()
Don't like Apple because while their products look good, they are not the best made.
Also, some of their business practices leave a lot to be desired. Not a fan of the locked down nature of the apps store, for example. Another example is them being able to remove an app off the phone after it has been installed.
As for the other, what is OP?![]()
Great, others do (like me). As for locked down, they're restricting what applications can do (nothing even slightly sexual) and the App Store is the only way to get applications on your phone without jailbreaking it. Those problems are certainly enough for me not to want to have an iPhone again (I used to own one but sold it and got an Android handset instead).I have no problem with the App store, explain what you mean by "locked down"?
Price/performance is important to me as I am not made of money. It is more important than style, which means the iPhone does not have an advantage there. The iPhone fails on performance because multitasking in 3rd party apps is not enabled.Original Post / Poster.
Their products look good and are very well made, You dislike them because they're expensive?
A smartphone that doesn't allow multitasking with 3rd party apps is a broken smartphone. I like to read on Opera. I wouldn't be able to on the iPhone because every time I did something else on it the phone would shut down Opera and I would have to go find my place/webpage again.
That's poor design, and its a poor design that they deliberately put there because Apple knows best.
I do envy the style with which Apple do things, but the iPhone doesn't do what I want it to do due to Apple's decision to remove a feature that other smartphones have had for years.
Great
Did you enjoy sexual games on your iphone before this then?
It seems to me, with the App store. You won't have a problem, unless you start nit picking through things. "restrictive" with Adult material? whatever next.
irrelevant stuff
Do you know that Apple could have (and may have actually done) destroyed people's businesses when they decided to remove numerous applications from their store without consultation or warning? Do you care?
Did you see where I said 3rd party?
