Robocain - Robocop 2 robot
drilled through the box thing and made a pin to pivot it on, took ages to get it to close flush
made some mounting points at the back to screw it to the mounting plate
and decided to cut a fresh plate out this one has been modified one time too many.
starting on the chest, looking like a big washing machine drum
realised after cutting the big disk that it just wasnt big enough, looks wrong to the pics
so ended up making a slightly larger one
profile....
Insane stuff, really impressive.
I hope you keep a good metallic/real looking finish after painting it. Would be a shame to paint it all then be hard pressed to tell it apart from a mould! :D
More updates! :)
Once again incredible work.
When this is done you should send a link to the photo/info page to Adam Savage (from the Discovery tv show Mythbusters), he does stuff like this (made the pistol from Blade Runner for e.g) but on no-where near the scale of some of your projects!
Well im in Florida this week but you'll be pleased to know I kept some updates back so you dont get Cain withdrawal! good thinking huh :p
I recessed where all the screws sit with a 3mm mill then drilled and tapped them, turned the screws down too.
Next I made a pair of these blocks on a slight angle that will go into the back of the drum and allow them to be adjusted a bit and then held in place
something like that
on to the other side, turned more or less the same size with some beveling and recesses
it needs a U shaped piece on the front of it, after a bit of thought I decided just to do it by hand. Its only a 1 off and by the time I'd setup the rotary table and clamped such a small piece down I could have made it.
something like that
bolt it on for a trial fit
next back to the delrin for the cover that goes on the chest
after fixing the "U" on I milled out room for the cover.
and that sits in there nice :)
Good god, this is simply awesome.
Might of missed it, what kind of workshop set up do you have.
Assuming you must have full on lathes and pillar drills.
More updates! :)
This is exactly why i was thinking that home anodising would be a better option than painting. You can get some awesome results and its a finish that is beneath the surface so it'll retain all the detail and be far more durable.
Despite me checking this thread every time it is updated; I am still more and more amazed by your work! Can't wait for the final product :)
..I have no words for how truly amazing this is!...really, sheer craftmanship which is sadly rarly seen today!
