Per blade as mentionedthat each side of the blade or per blade?
Let me know how you get along with that Future as I am not a fan of my one, which was my first purchase. I too have that brush and soap
I was ill throughout the week but gave it a test run. Oh lord, is it's aggressive reputation true. It cut through my hair like a hot knife through you know what vs my old 34c. I was using Iridium blades for this task, as I feared Feathers would just be TOO close and sharp with this razor.
Tbh mglover, i'm of the opinion that when it comes to the razor, technique is more important than the type of razor you use. Cream, brushes etc will always be important as you've rightly said but again as you've said, as long as you use the right technique a cheap bic razor will do the job fine.
With that said i'll never give up my 34C, it looks cool and it is a hell of a lot cheaper to replace the blades.
The good thing about a safety razor is that it teaches you good technique. After a few months with it you could go back to a 'normal' razor and shave without issue (but probably won't as safety razors are just better). The thing about 'normal' razors is that they don't punish you in an obvious way if you use them poorly, they give you a rash and some discomfort over the next few hours but it's difficult to associate it with exactly what you did wrong.
When you screw up with a safety razor you know about it, fast. But that's the good thing, you know what you did wrong so you can avoid doing it in the future.
After 6 years of razor burn and pouring money down the sink going from Mach 3 to Fusion to Quattro and Azor, none of which gave that much of an improvement (I used to choose which to use based on what blades were on offer!) I suspect DE shaving is going to be far better in the long run!
My 2nd Murkur shave gave me HORRENDOUS razor burn!
Turns out that whilst I was 'barely applying pressure' compared to my mach3, I was still using far too much pressure. You really have to use very very little pressure on your skin. Again, my bad habits of ramming the mach3 into my face, gritting my teeth, and ploughing it through my chin stubble had given me poor techniques.
.Was using a Merkur with the standard blades for about a year. Got the feather blades and wow what a difference they make. Amazing shave. Shaving can actually be enjoyable now.
Any hints?This. I used the standard blades and really hated shaving so went back to the cartridge ones. Spent £2.50 on a pack of 10 Derbys and haven't looked back.
I find it difficult to create a good lather though. I seem to use a lot of soap tooAny hints?
Right im sick of paying a fortune for blades. I like to leave my shaves till I get a slight beard. Can someone recomend me a razor, brush and blades and foam? . Doesnt need to be really cheap but nothing extreme. Want to give this stuff a go
ta
I think, razor wise, you can't go wrong with a Merkur 34C.
Blades are personal choice so I would get a sample pack first to find out which ones suit you best. Although Israelis and Derbys are good starters.
I'm currently using L'Occitane Cade shaving soap and Clinique Post-Shave Healer, although Taylor Of Old Bond St and Mitchell's soaps are also meant to be good. Again soap/shaving balm is personal choice.
