- 6 Nov 2002
Anyone got any advice on which replacement air filter is best for my 172?
Seems to be a choice of:
ITG
K&N
Green
Pipercross
Cheers![]()
Speak to JMS Tuning
ITG
K&N
Green
Pipercross
Cheers![]()
ITG
K&N
Green
Pipercross
Cheers![]()
I've been sort of looking at late 172's /early 182's recently, as a possible replacement for my Fiat. Seems I get something not too much slower, but with the potential of better economy on my commute, and something that handles well.
One thing I have seen mentioned a lot is timing belt replacement; is it a particularly nasty job on these engines? It doesn't look too bad to me, certainly an awful lot better than the Fiat.
Also a couple of the buyers guides I have read suggest clutches don't tend to last much more than 60k miles - is this simply a consequence of the way people drive them or are they just a bit "French" in the longevity department?
Timing belt is a bit of a pain, just need to slacken the mounts so you can move the engine up and down to get to various bits I've been told. And you do need the locking tools to do it properly.
Even so, it's £500 from a specialist and that's with the full cambelt kit (which includes all the tensioners) and the full aux belt kit.
Which considering how cheap they are to run the rest of the time I didn't mind that.
Ok due to some financial problems i can not get the 5k i wanted to buy a celica
So i will have around 3k now. 172 looks a cracking buy for the money is it worth looking at the 3k budget? or will they all be nailed?
My 182 is giving me yet MORE problems. There is a nasty metallic rattle coming from under the car (around the cat). I think the exhaust is screwed, so when I get paid at the end of the month a Milltek will be going on, and I'll probably treat myself to some Eibach Sportlines. Next up, some Turinis, then that is everyone that I want done, done.
Passing curiosity
What are the differences between the pre and post facelift 172s and further the 182?
So if you wanted a fun run-around on a budget, then you'd either spend a bit of money for a Cup or buy the phase 1?
you would get a tidy one for £3k mate
have a look in the for sale section on CS forums, theres a few for sale.
Good thing about buying from CS forums is, they do not allow you to edit your own posts, so if you see a car you like you just search all posts made by that user and instantly have history on the car and any work that has been done to it etc
Has anybody got any experience with K-Tek in Verwood, Dorset? I'm going with my girlfriend's Dad to get his 182 remapped on Thursday and they said that it's costing About £200-£250 I think. Requires a dyno run, then the remap, and then another dyno run - dyno run is £45 each!
We're also thinking that with a bit of extra power, the brakes are likely to have to be upgraded too - any recommendations?
