- 2 Oct 2007
- Oxfordshire
Right then, just about to get the bus into my local 02 to get my shiny new phone (they have them in stock, just called and checked
these are not official firmwares and i believe might effect warranty.
ok just done the lag fix with jm2 using ext4, quadrant is 1737
speed is unreal![]()
ext4 defo the way to go, just remember to use the ext4 fix file and not the one for ext3
gparted worked a treat.
Anyone got their Facebook contacts to sync and show in the contacts??
I have added my account and ran sync several times, also set contacts to display facebook, but when I look in the groups, the facebook group is empty??
What am I doing wrong....?
You can sign up at the link below you want firmwares then pick android, then galaxy s, these are not official firmwares and i believe might effect warranty.
Currently i am using the JM2 one and its good big improvement for me, specially if you do the lag fix also makes the phone swet.
http://samsung-firmware.webs.com/
