Ok then, obviously defrost 2.5a just isn't compatible with minimal matte grey then as I got an error when I did that. Assumed I was doing it wrong.
That's because you're a giant NEWB! Disable verification first, then flash
I've not had an email but I've got access to AppInventor at last![]()
what roms are there that have sense underneath? ive realised with root id loose the stock/shares thing HTC have made and i havent found a suitable alternative
hey honkies, what's this icon?
Looks like the wifi hotspot logo but mine appears on the left when connected and has 3G within the brackets/waves if a mobile data connection is on![]()
is that in recovery menu? The blackbar theme went on fine...
Well my mate just got ordered a desire from orange and I was reading how to unbrand it without making a gold card.
My battery life is all over the place. Sunday, unplugged from 8am. Light usage, some web browsing and by 8pm I had 70% left.
Today, unplug at 6am, and I'm already down to 68%. What battery app can I get which shows me exactly what is killing it?
LeeDroid 1.7b by the way
Is there any way to find out if my apps are using froyo a2sd or my sd-ext partition?
Connect your phone to your PC and see if there are app folders on your sd card? I'm assuming that you can't view ext3/ext4 partitions in windows so if you can't find the app. folders then they're on your extended partition.
How so?
Got download?
