Did you install the HBoot driver in windows first mate ?
It really is easy to do, It 'reads' like double dutch to us that don't know all the technical jargon, I kept on with it and it installed fine, Best thing i have 'installed' since rooting to be honest.
That passion not supported message is because your current rom is based on a nexus build. I had the issue with it. Had to flash something else to get it to do it.
Edit: must learn to read lol. In my defense I'm browsing on my phone and tired waiting to go to work.
Same as flashing roms. In recovery, select flash zip from SD card, locate the zip and confirm. The phone will reboot a few times then boot up as normal with the new radio.
Has anyone had issues with the phone slowing down and memory being consumed even though no apps are running? Looking in App killer I'll have nothing running but only 90mb of free memory. Rebooting fixes the issue and gives me back 220mb ish free memory, untill it drops again.
Is it just a case of the phone being left on for too long and not having had a reboot in a while?
