Hi All
Re the runes and glyphs etc
Im level 7 now.What runes and glyphs should i get.I can only get the lesser glyphs.Do they make much difference.By the way i currently play as Ashe at the moment.Thanks for any tips.Is there any good guides of what weapons to buy and armor etc from the get go as i often get confused and probably dont make the best choices.
Thanks
TBH, if your level 7 and playing as Ashe I'd wait till you hit level 21, so you can buy Tier 3 runes. As the Tier 1 are a waste of IP.
As for Ashe guides, try Leaguecraft--http://leaguecraft.com/strategies/guides/?filter=d56056f9c9f98d41824f05ccba6ebc3d
