All it needs is a new GPU and you have a PC almost as good as any really.
Yes the only reason GTA4 and Crysis run worse than Batman: AA is they're badly coded...
I agree with that to be fair. Warhead runs vastly better than crysis for sod all reason. With GTA4 it's just the product of a very lazy port as you can't even enable AA in the game which is pretty crap for a newer game. On my desktop pc I can run GTA4 smoothly on the "max" settings but have to turn the view distance and shadow distance sliders down to around 40 otherwise its a pure slideshow.
Warhead didn't look quite as good imo and when you compare the console versions of GTA4 you'd have to run at 1280x720 max and with low \ medium details and shadows turned down or off. Also no AA is because of the lighting method it uses, you can't blame that on bad coding.
My samsung 22inch 1080p monitor is the best and worst upgrade I've ever bought due to the same reason lol.
I went from a 17inch tft where my 8800GT could play everything really well, even crysis then gave it over twice the amount of pixels to play with and had to upgrade my entire PC to handle it![]()
You could have just stopped at "My Samsung 22inch 1080p monitor is the best and worst upgrade I've ever bought". LOL!
I've never heard of such a small 1080p monitor,
Yes, except for Crysis and Metro 2033.
