- 8 Nov 2006
sunk the tiny screws into the clamp joint parts
had to make some odd parts and disks etc to join everything together
realised it was too short so had a re-design and spaced it out a bit more, this section will be covered so it doesnt need to be as detailed.
This arm has the spot welder thing on it, hard to know where to start on such a complex lump, so after some thought and a lot of measuring im quite happy with this
looks about the right size to me, trim the middle out
and the top, sitting on another turner prize of a diagram that looks like a cross between a babies rattle and a policeman hiding behind a tomb stone
carefully recessed the edges and drilled through so they lign up top and bottom.
