- 5 Jun 2003
- Falling...
Lots of my friends are trying to get me to compete - I have no interest in it though. Good luck  sure you'll be getting pro help, but  if you want support - we'll be here!
 Yeah to be honest, I would feel most comfortable getting advice and support from you guys. Just because you are a friendly lot
 Yeah to be honest, I would feel most comfortable getting advice and support from you guys. Just because you are a friendly lot  and because there is a vast amount of knowledge on here that would be massively useful
Anyone on here going to compete next year? I know most people do it as a hobby but just incase anyone is
I've always said it would just be a hobby, but I've made such good gains in this last year and a half that I think another 6 months training at this level, I could easily get to competition level
So I'm going to be entering the BNBF Southern qualifiers next year. It will be a one off thing for me, but I want to say I at least did it. And to prove to myself I can have the dedication to do it
 that I ever do this, but it will be something I'll be hugely proud of to be able to look back and say I did that
 that I ever do this, but it will be something I'll be hugely proud of to be able to look back and say I did thatStart going heavy SPW - less reps, but really heavy. Lots of sets of 2s and 3s.
Endurance. NOT TONING!If anybody ever tells you they're 'toning' slap them and walk away.
Strength
It's quite simple. This is how I would break it down for you:
Strength: 3-6 reps 80% + of load of 1RM. As fast a concentric (push) contraction as possible
Mass: 8-12 reps 50-70% load of 1RM. Nice controlled eccentric (lowering) contractions. Lots of control as opposed to throwing weight around.
Examples of tempo's might be 2.0.1 or 2.0.0 - two second lowering phase, no pause, and one second push phase or in the case of a zero as fast as possible. 4.0.2 would be 4 seconds lowering, no pause and 2 seconds pushing.
Endurance: 12 reps + 50% or less of 1RM. Still controlled but not as slow reps in some cases.
Some of the above go hand in hand.
Strength training you'll see less physical growth (hypertrophy) or mass however you should still see some.
Mass training you'll probaly notice some slight increases in strength and quite possibly endurance too.
Endurance training won't really do much for mass or strength but should help to improve your recovery and is also good to throw it in every now and then to mix it up and also de-load your muscles.
Hope this helps and isnt too confusing.
Well I've had a look and I'm starting HST next week after a week of rest and some cardio if my cold gets better.
I've been eating around 2600 but have increased this to 3000 over the last 4 weeks at 100 cals per day per week feeling quite strong which is nice quite happily bang out 3 sets of 10 chins 3-4 times a week I could only do 2 this time last year(chins not sets)
Trying to sort my routine for HST so I'll post this up later but here is my diet if any one is interested It's minus 2 lots of milk which add 200 cals and I'm back on the protein powder but hay hum lol.
This is most days but not every day. breakfast being my favourite meal of he day
I think FF was talking to semi-pro waster
Makes sense...I did wonder
Oh, and can I say thanks to all the people who said to toast the pitas...Much easier in the mornings now
have you managed to find anything decent locally second hand? i notice you mention buying a rack up above, tbh a rack is useless without a olympic bar, the other bars arent long enough to use inside it, i think you need a 7 foot bar to use inside most racks, i know some are designed to be used with 6 feet, but they are the minority. my bar is 7 foot and fits perfectly into my powertec rack. i know that a 6 foot bar would be too small for my rack.
so there's no point you buying the rack unless you can get the right size bar, unless your getting it cheap then its worth buying now rather than paying more later. does that sound right to you? its confusing lol.
i should be picking up my dumbells today, second hand, brand new cost over £500. Im getting them for £300, plus a dumbell rack, plus some mats. so im saving well over £200 probably even over £300 if they are decent mats.
).I know I'll need new weights etc...It's annoying
I've seen some 'cheap' deals with olympic bars and a fair few weights for me...But yes I'd love a squat rack in the long run, so I can actually bench properly as well...Kind of hard to lug 30kg over your groin while you try and set up, let alone dangerous...Luckily I can actually man handle the weight at the moment safely, but any heavier it's just stupid and I wouldn't do it...So I'll no doubt have to goto DB's again for the time being
I'm trying to save up, but at the same time I don't know if we're staying in this house for 'x' amount of years, so probably wouldn't be worth it anyway!
It all sucks really.
Yes, I should join a gym, but atm I can't due to the way my lifestyle is really, I can't afford to drive to different gyms everywhere after work, and we also share a car, so yeah
You'll want a 7ft bar with a powerrack, my CF475 needs a 7 foot and it's not even a big rack. Gives you abour 3 inches of 'wriggle' in the hooks before you knock on the butt of the bars horn (bit where you put the plates).
fitnesssuperstore, do some quite cheap ones. End of the day a bar is a bar as long as it doesn't perform like a noodle and the ends spin/have some bearing it'll be fine.
Delvis: If you're struggling to squat because of lack of equipment try some bulgarian split squats, just hold the plates in either hand. Much tougher than they look.
Edit:
http://www.fitness-superstore.co.uk...7_olympic_bar_320kg___700lb_rated/3202_p.html
http://www.fitness-superstore.co.uk/olympic_weight_sets/10229_0c.html
http://www.fitness-superstore.co.uk/olympic_weight_plates/10061_0c.html
Lots of reasonably priced weight sets there. Or you can buy the bar and plates as you go.
squat rack is a good compromise over a power rack if your wanting to do a basic set of exercises. the reason why i went with a power rack is for the lat tower attachment, obviously this means spending a lot more money but i can now do practically every exercise, and hit the same muscle using varied exercises.
so you will obviously have to work out, whats better for you, everybody's needs and wants are different. you dont want to in 2 years time look back and think damn i should have just saved for a while longer or searched a bit harder for something better. so take your time in making your decision and keep looking on ebay and gumtree. gumtree is better for cheapness, but its a lot harder to find a good deal on it.
I wish I bought a squat rack. Like you say, buy an adjustable bench and can do bench press in it as well! I'd say save up and buy one if you can!
