Man of Honour
- 21 Nov 2004
Does anybody know how to copy your team mates setup? My engineer keeps saying I should but I can't find the option!
Wondering the same myself! Can't find an option anywhere.
please![]()
[TW]Fox;17430279 said:This game is driving me up the wall - constant penalties for 'corner cutting'.
I am not very good at this game, this much is evident, but the constant penalties are driving me insane. I am not gaining time when I 'cut' corners. I'm not even cutting corners, most of the time I'm going wide or or slowing to 10mph in gravel.
I even managed to get 'disqualified' despite the 'cut' I took leading straight to a wall, which I collided with!
Surely you should only be penalised when you gain an advantage? Giving me a disqualificating from the race when I am reversing out of my crash back onto the track is stupid!
while the game was running? and are you getting good performance or stuck at around 30fps?Ran mine, looks just like your top graph, all normal green.
ATI or Nvidia?While running.
I get about 60-90fps with the occasion dip down to early 50's, ive not seen it any lower than that though. Only with vsync off, with vsync on, it was about 30-45
was his GPU usage quite low while he is on track?My mate just tried that for you and it was normal green but stuck at 32fps.
This was on a GTX275 OC and Q9550 and 4gig of ram..windows 7 64(same setup as me).
What I did notice is that when I OC his Q9550 from 2.8 to 3.6ghz the game still thought it was 2.8ghz
I think I will get this now(maybe).
You're getting penalties for "Driving outside the confindes of the track", for some reason, it's just showing as cutting corners.[TW]Fox;17430279 said:This game is driving me up the wall - constant penalties for 'corner cutting'.
Seems as he is on Win7, the easiest way is to install this gadgetSorry I don't know. I can call and ask him but what software does he need to tell what GPU usage?
http://blog.orbmu2k.de/sidebar-gadgets/gpu-observer-sidebar-gadget
Also did he check the dpc latency while he was out driving on the track? as its fine for me in the menu's but once you hit the track it shoots up.OK..I will tell him now and get back to you.
