- 11 Dec 2005
- Cheshire
Asus X58 Sabertooth TUF Intel X58 (Socket 1366) DDR3 Motherboard @ £156.99 inc VAT
Covering all the Essentials of Reliability
The key emphasis for TUF Series motherboards lies in enabling prolonged use. The SABERTOOTH X58 can keep going round the clock with no pause thanks to its meticulous thermal design, which means heat and stress are not obstacles. This new thermal design revolves around CeraM!X Heatsink Coating Technology, using revolutionary ceramic application on vital motherboard surfaces and components to ensure unrivalled heat resistance and dissipation. Thus, it is the perfect choice for server functionality and extreme, steady reliability. CeraM!X application has never been done on a motherboard before the ASUS TUF Series entered service.
Reliability Tested to Military Grade
The SABERTOOTH X58 from ASUS uses heavy duty materials and parts to ensure truly unmatched capabilities in terms of stability, reliability, endurance, and value.
The chokes, solid state capacitors and MOSFETs have all been tested under the most arduous of conditions and harsh environments based on military standards, providing users with a proven heavy duty solution.
TUF Series motherboards are ruggedized from the ground up, so they can handle more than just long-haul usage and heat. They are also tested to server-grade standards and can stand up to humidity and ambient temperatures to an exponentially larger extent than normal motherboards. As a consequence, they are long-life products users can install with complete confidence.
Being strong does not mean TUF Series motherboards compromise added features. The SABERTOOTH X58 ships with new data transfer standards USB 3.0 and SATA 6GB/s, so it offers some of the latest innovations in addition to superior strength. It is a complete package of guaranteed reliability and compatibility.
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express
- Memory: 6x DDR3 DIMM 1866 /1800 / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 1 PCIe x4 Slot, 2x PCIe x1 Slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
- 8 Phase Power Design
- MemOK!
- T.U.F. Power engine design
- T.U.F. Components: Chokes, capacitors and MOSFETS certified to military standards
- E.S.P - Efficient Power Switching
- CeraM!X Heatsink coating technology
- Asus Fan Xpert
- Form Factor: ATX 12x9.6 inches
Only £156.99 inc VAT.
ORDER NOW
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- MemOK!
- Asus Fan Xpert
ORDER NOW
will their be limited stock?
