Well...two weeks off, and my shoulders still feeling a bit gammy =/
Not sure what to do now, may just start again to be honest
Just take it steady, if all you can do is cardio for now so be it.
No point over doing it and causing more lasting injury
like Morba said just leave it and if needed go to doc.
I trained on a knee that was "feeling a bit gammy" for a few months and as a result could do no direct leg work for about 4-5 months
you must be itching mate, if i miss just one day i'm craving a workout
but as already said, wait it out and avoid any lasting injurys!!
Well yesterday I managed to finally use the pair of 40's for my DB Incline Press. Was so pleased with myself - if only for the psychological factor of using the last DB's in that row. I needed help to get them up, but managed 5 reps once someone straightened my arms for the 1st rep.
Personally would go a bit heavier. Maybe 55/60KG for 4-6 reps x 3 sets
Depends just how 'heavy' you plan on going.
Can always do an ascending pyramid and see how it goes. e.g:
Well how heavy should I go? Normally I just bust out the same amount of reps and sets with the same weight, and I figure mixing it up will only be of benefit. I'm just not too sure on what figures I should be tweaking. I thought the norm when reducing the amount of reps (and increasing weight) was to also do more sets?
I like the ascending pyramid, would you recommend doing a drop set once you peak?
Also bearing in mind I'll also be doing DB Bench, Incline DB Bench, flies, and the wide chest press machine at my gym - im guessing I don't want to use all my energy on just the bench!
Going for power lifting comp next year. Will 100% not be attempting Squat, my main lift I'm going for is bench and might try and bust out a deadlift who knows.
I'm going to be following
http://strongestman.org/?p=123
from December for the 9 weeks, will more than likely do that, cut for 8 weeks then do it again for 9 weeks and compete.
Well that's the idea
Also due to shoulder injury I will no longer be doing incline press.
Tricept exercises
Fella, you wanna find a good gym that has people doing board presses, that will help you a lot with this routine
