Maybe that's why they've not enabled it on 5 series yet officially, they must still be working on implementing it for such situations.
im certainly wrestling over what do with my 5870
was thinking to crossfire it but not sure now.
) and i dont see the 68xx doing so well in that regard (in terms of %age from stock). 58xx prices must come down now, if not new then in the second hand market. When the bottom falls out of the market I might snap one up for x-fire. As nice as these 68xx are, and I'm sure the 69xx will be, I've always skipped at least one gen after making a high-end purchase.im certainly wrestling over what do with my 5870
I'm happy with my 5850 for now. It overclocks like a dream (see sig) and i dont see the 68xx doing so well in that regard (in terms of %age from stock). 58xx prices must come down now, if not new then in the second hand market. When the bottom falls out of the market I might snap one up for x-fire. As nice as these 68xx are, and I'm sure the 69xx will be, I've always skipped at least one gen after making a high-end purchase.
what voltage are you using for that clock?
Will this work on 5770's, no?
Works on mine. Don't have many games to test it fully on though.
Stuck it up to 1.2 for some furmark and crysis testing. Haven't tried to tweak it down to the limit of stability yet though, so it might go lower but probably not much. I think I got a good one![]()
IT WORKS!! I couldn't get vista 64 to install the modded hotfix 10.10a driver on my 2 year old windows install with a 4850 and 5850 at the same time. So I manually copied the d3d driver into the system, thanks to ze Zermans at 3dcenter forum.
1. Die .exe des Treibers entpacken (zB mit 7zip).
Extract the driver .exe (with, e.g. 7zip)
2. Die atiumdag.dl_ befindet sich nun in $_OUTDIR\Packages\Drivers\Display\W76A_INF\B107032 \ (bei Win64)
The atiumdag.dl_ is now in [given folder] (for Win64)
3. In der Eingabeaufforderung folgendes eingeben: expand atiumdag.dl_ atiumdag.dll
Enter the following in the command prompt: [the above]
4. Die expandierte atiumdag.dll nach Windows\SYSWOW64 kopieren. (vorhandene atiumdag.dll vorher sichern).
Move the expanded atiumdag.dll to [the given folder] (backup the already present atiumdag.dll before you do)
It still says gives an old driver package version and even an old d3d driver version, but MPAA works!
I also had to manually add the reg settings under these addresses:
; 5850
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ass\{4D36E968-E325-11CE-BFC1-08002BE10318}\0002\UMD
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Vi deo\{18FCE371-129F-4A2A-9371-D4BA4071CD49}\0000\UMD
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Vi deo\{18FCE371-129F-4A2A-9371-D4BA4071CD49}\0002\UMD
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Vi deo\{18FCE371-129F-4A2A-9371-D4BA4071CD49}\0001\UMD
; 4850
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ass\{4D36E968-E325-11CE-BFC1-08002BE10318}\0005\UMD
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Vi deo\{BD1512B5-6B3B-441F-B26B-DAC6BCA75AB0}\0000\UMD
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Vi deo\{BD1512B5-6B3B-441F-B26B-DAC6BCA75AB0}\0001\UMD
I used these settings from a couple posts above:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000]
"MLF_NA"="0"
"EnableUlps_NA"="0"
"SurfaceFormatReplacements_NA"="0"
"TFQ_NA"="0"
"TextureLod_NA"="0"
"DXVA_WMV_NA"="0"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\UMD]
"MLF_DEF"="0"
"EnableUlps_DEF"="0"
"SurfaceFormatReplacements_DEF"="0"
"TFQ_DEF"="1"
"AntiAliasSamples_SET"= "0,2,4,8"
"AntiAlias_DEF"="1"
"AntiAliasSamples_DEF"="0"
"AntiAliasMapping_SET"="0(0:0,1:0) 2(0:2,1:2) 4(0:4,1:4) 8(0:8,1:8,2:16)"
Google translation:Mind you, I have no idea what he means by the third step. I can see the dl file in the folder, but what command prompt? How do I know it's been 'expanded'? It's way too vague.
In step 3, I presume you open Command Prompt (find it in your Start Menu), navigate to that directory (in Command Prompt) and just type: expand atiumdag.dl_ atiumdag.dll1. The. Exe unpack the driver (eg with 7zip).
Extract the driver. Exe (with, e.g. 7zip)
2. The atiumdag.dl_ is now in $ _OUTDIR \ Packages \ Drivers \ Display \ W76A_INF \ B107032 \ (for Win64)
3. In the command prompt, enter: expand atiumdag.dl_ atiumdag.dll
Enter the following at the command prompt: [the above]
4. The expanded atiumdag.dll copy to Windows \ SysWOW64. (Existing secure atiumdag.dll before).
