Man of Honour
- 21 Nov 2004
The fix worked for me
- and I NEVER had puddles on the track even before the patch. So
After the patch i can only play in window mode. any ideas on how to get it full screen?
The fix worked for me- and I NEVER had puddles on the track even before the patch. So
just need to play in DX9 mode or suffer a mahoosive frame drop.It's awesome isn't it. Now you know what all the fuss was aboutjust need to play in DX9 mode or suffer a mahoosive frame drop.
Who knows, maybe CM will surprise us (probably won't) with another patch to sort this out and add a fps boost too. But I like it as it currently stands ... NOW MAKE 2011 YOU LAZY FU ...
No visible framedrop (although I am sure there is one)![]()
Yes turning puddles back on has brought the game back to pre-patch poor performance, it seems to me disabling puddles was the "optimizations" referred too in the patch notesI take it back. Quali seemed pretty stuttery to me. Is this a known problem then?
Wasn't the corrupt save bug one of the fixes in the patch ? at least I though it was ...
Sorry buddy but unless you have a backup before this happened then I don't think there is a way to get your data back.
Before the patch it was advised to only quit/exit to paddock after doing qualy as CM thinks quitting early caused the problem. This may apply again by the looks of things.
Edit: It was a fix ...
Now we are talking, a proper fix that doesn't kill performance, and it was down to a random forum member!!
http://community.codemasters.com/forum/6717556-post1.html
face it guys we have all been had over
f12010 = a pile of parp !!
can someone help me?
I dont have any of the lines that guy is talking about in my XML file!
i also dont have that XML file called workerMap2Core.xml
Glad I did not buy this, knew it would turn out like this just like Operation Flashpoint: DR. All hype, fancy graphics and promises of a good game. Codemasters just don't deliver.
