Yer def easier
and you dont even mention the quest helper.
lol, yes, I did a good amount of complaining about that when it was introduced so that will have to do.
I just can't believe how ridiculous its getting.
I remember one particularly, ok overly hard change in level's, in lone lands, the west side was essentially "low level" stuff, then as you hit the further east Wargs theres this sudden leap from 400-500morale mobs to 700-900 morale mobs, and around lvl 22-23 when that happened as a hunter you were only around 1200morale or something.
They did used to be odd "jumps" in enemy morale/damage at various points with the lone lands the biggest jump across just a couple levels of mobs. They've smoothed it out somewhat but always lowering it inline with the easiest mobs in an area.
This time around those same wargs were down to 450morale and my Guard was hovering around 2k morale.
Every expansion just gets easier all over to the point its not a challenge to play.
Anyway, does anyone know how much Moria and Mirkwood expansions are in the lotro store as, you can't see prices for stuff you already have. I'm guessing next one will cost similar to what Mirkwood costs now?
Can't work out whats worth buying with points, I've got loads, though bit of a scam we don't get old deed's points applied, as I'd have a ridiculous amount of points.
